Dell Inspiron 13-5368 Webcam Replacement
  1. Dell Inspiron 13-5368 Webcam Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 13-5368 Webcam Replacement, Battery: step 1, image 2 of 2
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
  2. Dell Inspiron 13-5368 Webcam Replacement: step 2, image 1 of 2 Dell Inspiron 13-5368 Webcam Replacement: step 2, image 2 of 2
    • Use a spudger to pry up and remove the back cover.
  3. Dell Inspiron 13-5368 Webcam Replacement: step 3, image 1 of 1
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
  4. Dell Inspiron 13-5368 Webcam Replacement: step 4, image 1 of 1
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
  5. Dell Inspiron 13-5368 Webcam Replacement: step 5, image 1 of 2 Dell Inspiron 13-5368 Webcam Replacement: step 5, image 2 of 2
    • Remove the battery.
  6. Dell Inspiron 13-5368 Webcam Replacement, Screen Display: step 6, image 1 of 3 Dell Inspiron 13-5368 Webcam Replacement, Screen Display: step 6, image 2 of 3 Dell Inspiron 13-5368 Webcam Replacement, Screen Display: step 6, image 3 of 3
    • Unscrew the 2mm screw that holds the WLAN card. Then carefully remove the WLAN card from the motherboard.
  7. Dell Inspiron 13-5368 Webcam Replacement: step 7, image 1 of 1
    • Detach the black and white antenna cables from the WLAN card.
  8. Dell Inspiron 13-5368 Webcam Replacement: step 8, image 1 of 1
    • Unplug the two display cables.
  9. Dell Inspiron 13-5368 Webcam Replacement: step 9, image 1 of 1
    • Unscrew the screws that are securing the laptop's hinges.
  10. Dell Inspiron 13-5368 Webcam Replacement: step 10, image 1 of 1
    • Detach the display from the base.
  11. Dell Inspiron 13-5368 Webcam Replacement, Webcam: step 11, image 1 of 1
    • Use your plastic opening tool to pry the LCD back cover from the display panel.
  12. Dell Inspiron 13-5368 Webcam Replacement: step 12, image 1 of 2 Dell Inspiron 13-5368 Webcam Replacement: step 12, image 2 of 2
    • Carefully separate the back cover from the LCD screen.
    • Carefully remove the ribbon cable that holds the webcam to the screen, then unplug the webcam from the ribbon cable.
Matt Sugrim
1,042 Reputation
6 Guides authored
USF Tampa, Team S14-G6, Boczar Fall 2017 Member of USF Tampa, Team S14-G6, Boczar Fall 2017
USFT-BOCZAR-F17S14G6
4 Members
13 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 17
All Time: 1,241
