Dell Inspiron 13-7352 Cooling Fan Replacement
  1. Dell Inspiron 13-7352 Cooling Fan Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 13-7352 Cooling Fan Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 13-7352 Cooling Fan Replacement, Battery: step 1, image 3 of 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Cooling Fan Replacement: step 2, image 1 of 2 Dell Inspiron 13-7352 Cooling Fan Replacement: step 2, image 2 of 2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Cooling Fan Replacement: step 3, image 1 of 1
    • Gently remove the battery from the rest of the device.
  4. Dell Inspiron 13-7352 Cooling Fan Replacement, Cooling Fan: step 4, image 1 of 2 Dell Inspiron 13-7352 Cooling Fan Replacement, Cooling Fan: step 4, image 2 of 2
    • Remove the cord that runs from system board to the I/O board.
  5. Dell Inspiron 13-7352 Cooling Fan Replacement: step 5, image 1 of 2 Dell Inspiron 13-7352 Cooling Fan Replacement: step 5, image 2 of 2
    • Remove the 3mm and 4mm screws holding down fan with the Phillips #0 head.
    • Disconnect the fan wire from the system board.
  6. Dell Inspiron 13-7352 Cooling Fan Replacement: step 6, image 1 of 1
    • Lift the fan from the rest of the device by picking up a single side and separating it from device.
Chris Monte
393 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 8
All Time: 2,219
