Dell Inspiron 13-7352 DC POWER JACK HARNESS Replacement
  1. Dell Inspiron 13-7352 DC POWER JACK HARNESS  Replacement, Back Panel Removal: step 1, image 1 of 3 Dell Inspiron 13-7352 DC POWER JACK HARNESS  Replacement, Back Panel Removal: step 1, image 2 of 3 Dell Inspiron 13-7352 DC POWER JACK HARNESS  Replacement, Back Panel Removal: step 1, image 3 of 3
    • Before disassembling your laptop, be sure it is powered off.
    • Remove the ten 7.5mm screws that secure the back panel with the Phillips #0 head
    • Use the plastic opening tool to remove the back panel. Start at the back corner and work across. The front edge of the laptop panel hinges and pivots upward after the back edge and the side edges are separated from the casing.
  2. Dell Inspiron 13-7352 DC POWER JACK HARNESS  Replacement: step 2, image 1 of 3 Dell Inspiron 13-7352 DC POWER JACK HARNESS  Replacement: step 2, image 2 of 3 Dell Inspiron 13-7352 DC POWER JACK HARNESS  Replacement: step 2, image 3 of 3
    • Remove the one 4mm screw with the Phillips #0 head that hold down the battery.
    • Use the plastic opening tool to remove DC Power Jack harness connector from the motherboard.
    • Gently remove the DC power jack harness from the device and replace it with a new one.
Anthony Burke
109 Reputation
1 Guide authored
MWP Supply, Inc. Member of MWP Supply, Inc.
Business
1 Member
1 Guide authored
One Comment
This is perfect, but I’m curious how others may have handled an issue where the screw hole for my 7359’s power jack disintegrated. Anyone have any idea on how to anchor a power jack without that screw hole? I tried Sugru to mold around it, but that didn’t work. Any other ideas would be welcome.
Harry Morgan - Reply
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 20
All Time: 867
