Dell Inspiron 13-7352 System Board Replacement
  1. Dell Inspiron 13-7352 System Board Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 13-7352 System Board Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 13-7352 System Board Replacement, Battery: step 1, image 3 of 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 System Board Replacement: step 2, image 1 of 2 Dell Inspiron 13-7352 System Board Replacement: step 2, image 2 of 2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 System Board Replacement: step 3, image 1 of 1
    • Gently remove the battery from the rest of the device.
  4. Careful: steps 4-5 are sourced from a guide that's marked as in-progress.
    Dell Inspiron 13-7352 System Board Replacement, Memory Module (RAM): step 4, image 1 of 3 Dell Inspiron 13-7352 System Board Replacement, Memory Module (RAM): step 4, image 2 of 3 Dell Inspiron 13-7352 System Board Replacement, Memory Module (RAM): step 4, image 3 of 3
    • Locate your memory module (RAM).
    • Release the clips from the Memory Module by gently pushing down. This should cause the Memory Module to pop up and separate from the device base.
  5. Dell Inspiron 13-7352 System Board Replacement: step 5, image 1 of 1
    • Pull the Memory Module from its slot by grasping each side with thumb and middle or index finger to pull from the rest of the device.
  6. Dell Inspiron 13-7352 System Board Replacement, System Board: step 6, image 1 of 3 Dell Inspiron 13-7352 System Board Replacement, System Board: step 6, image 2 of 3 Dell Inspiron 13-7352 System Board Replacement, System Board: step 6, image 3 of 3
    • Remove cord that runs from system board to the I/O board.
    • Remove connecting wire that runs from fan to system board.
  7. Dell Inspiron 13-7352 System Board Replacement: step 7, image 1 of 1
    • Remove the 3mm and 4mm screws using the Phillips #0 head for both that hold down the fan
  8. Dell Inspiron 13-7352 System Board Replacement: step 8, image 1 of 1
    • Lift the fan from the system board by using your thumb and index or middle finger to gently pull away from the rest of the device.
  9. Dell Inspiron 13-7352 System Board Replacement: step 9, image 1 of 3 Dell Inspiron 13-7352 System Board Replacement: step 9, image 2 of 3 Dell Inspiron 13-7352 System Board Replacement: step 9, image 3 of 3
    • Remove the three 4mm screws with the Phillips #0 holding down the heat sink.
    • Remove the two 4mm screws with the Phillips #0 holding down the metal bracket.
    • Unscrew the single 3mm screw using the Phillips #0 head securing the system board.
  10. Dell Inspiron 13-7352 System Board Replacement: step 10, image 1 of 2 Dell Inspiron 13-7352 System Board Replacement: step 10, image 2 of 2
    • Remove the wire connections attached to the system board.
    • Remove the tape wires from the system board.
  11. Dell Inspiron 13-7352 System Board Replacement: step 11, image 1 of 1
    • Carefully remove the system board from the base by grasping with thumb and index or middle finger and pulling away from the rest of the device.
2 other people completed this guide.
Chris Monte
393 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,842
