Dell Inspiron 13-7353 Palmrest Keyboard Replacement
  1. Dell Inspiron 13-7353 Palmrest Keyboard Replacement, Palmrest Keyboard and Touchpad: step 1, image 1 of 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement, Palmrest Keyboard and Touchpad: step 1, image 2 of 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement, Palmrest Keyboard and Touchpad: step 1, image 3 of 3
    • Remove the 10 - M2.5 x 8mm screws located on the bottom of the device.
    • Detach and remove the Bottom Base Cover using an opening tool to pry it off.
  2. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 2, image 1 of 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 2, image 2 of 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 2, image 3 of 3
    • Unplug and gently pull the hard drive cable to loosen it.
    • Remove the 2 - M2 x 3mm screws.
    • Remove the Battery.
  3. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 3, image 1 of 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 3, image 2 of 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 3, image 3 of 3
    • Remove the 2 - M2 x 3mm hard drive screws.
    • Remove the Hard Drive.
  4. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 4, image 1 of 2 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 4, image 2 of 2
    • Unplug the speaker cable.
    • Remove the Speakers.
  5. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 5, image 1 of 2 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 5, image 2 of 2
    • Unplug the fan cable.
    • Unplug and remove the daughter board cable.
  6. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 6, image 1 of 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 6, image 2 of 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 6, image 3 of 3
    • Unplug the antenna cables.
    • Unplug the power button cable.
  7. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 7, image 1 of 2 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 7, image 2 of 2
    • Remove the 1 - M2 x 3mm screw.
    • Remove the USB / SD Card Circuit Board.
  8. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 8, image 1 of 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 8, image 2 of 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 8, image 3 of 3
    • Remove the 1 - M2 x 3mm and 1 - M2 x 2mm Wafer screw.
    • Remove the Cooling Fan.
  9. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 9, image 1 of 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 9, image 2 of 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 9, image 3 of 3
    • Loosen the screws.
    • Remove the Heatsink.
  10. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 10, image 1 of 2 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 10, image 2 of 2
    • Remove the 2 - M2 x 3mm bracket screws.
    • Remove the LCD cable bracket.
  11. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 11, image 1 of 2 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 11, image 2 of 2
    • Unplug the LCD cable.
    • Unplug the touchscreen cable.
  12. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 12, image 1 of 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 12, image 2 of 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 12, image 3 of 3
    • Open the screen.
    • Loosen the LCD cable and peel it off of the base (highlighted with arrow).
    • Remove the 3 - M2.5 x 8mm hinge screws.
  13. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 13, image 1 of 2 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 13, image 2 of 2
    • Remove the screen assembly.
    • You may need to pull the hinges up.
  14. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 14, image 1 of 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 14, image 2 of 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 14, image 3 of 3
    • Unplug the cable.
    • Remove the DC Jack.
  15. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 15, image 1 of 2 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 15, image 2 of 2
    • Loosen the keyboard cable tape.
    • Loosen the keyboard cable latches.
    • Unplug the keyboard cable.
  16. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 16, image 1 of 1
    • Unplug the keyboard backlight cable.
    • Unplug the touchpad cable.
  17. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 17, image 1 of 2 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 17, image 2 of 2
    • Remove the 1 - M2 x 2mm Wafer screw.
    • Remove the Motherboard.
    • The piece remaining is the Palmrest Keyboard.
  18. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 18, image 1 of 1
    • You can further disassemble by removing the touchpad.
  19. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 19, image 1 of 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 19, image 2 of 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 19, image 3 of 3
    • Unscrew the 4 - 2x2mm wafer screws.
    • Peel back any tape holding the back plate on.
    • Lift and remove back plate.
  20. Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 20, image 1 of 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 20, image 2 of 3 Dell Inspiron 13-7353 Palmrest Keyboard Replacement: step 20, image 3 of 3
    • Peel back under-button tape.
    • Remove touchpad.
    • You have now stripped the keyboard! It is ready to be replaced.
5 other people completed this guide.
Attached Documents
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 7,282
