Dell Inspiron 13-7353 RAM Replacement
  1. Dell Inspiron 13-7353 RAM Replacement, Flip the Computer: step 1, image 1 of 1
    • WARNING: Please read the safety information shipped with your computer and follow recommended steps before working inside your computer. When finished working inside your computer, follow the instructions included in the safety information.
    • Close the computer display and turn the computer over so that the base of the computer is facing up.
  2. Dell Inspiron 13-7353 RAM Replacement, Secure the Base: step 2, image 1 of 1
    • Remove the ten screws that secure the base cover to the base of the computer.
  3. Dell Inspiron 13-7353 RAM Replacement, Pry the Base cover: step 3, image 1 of 1
    • Using a plastic scribe (plastic opening tool), pry the base cover off of the base of the computer.
  4. Dell Inspiron 13-7353 RAM Replacement, RAM: step 4, image 1 of 2 Dell Inspiron 13-7353 RAM Replacement, RAM: step 4, image 2 of 2
    • Before opening your device, ensure that all data is backed up on a hard drive to prevent data loss.
    • Loosen and then unplug the hard drive cable.
  5. Dell Inspiron 13-7353 RAM Replacement: step 5, image 1 of 2 Dell Inspiron 13-7353 RAM Replacement: step 5, image 2 of 2
    • Remove the two M2 3mm screws attaching the battery using the Phillips #1 screwdriver.
    • Remove the battery.
  6. Dell Inspiron 13-7353 RAM Replacement: step 6, image 1 of 3 Dell Inspiron 13-7353 RAM Replacement: step 6, image 2 of 3 Dell Inspiron 13-7353 RAM Replacement: step 6, image 3 of 3
    • Pry open the two clips.
    • Gently lift the RAM stick and pull it out of the motherboard.
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 12
All Time: 755
