Dell Inspiron 13-7359 Battery Replacement
  1. Dell Inspiron 13-7359 Battery Replacement, Battery: step 1, image 1 of 1
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 Battery Replacement: step 2, image 1 of 1
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 Battery Replacement: step 3, image 1 of 3 Dell Inspiron 13-7359 Battery Replacement: step 3, image 2 of 3 Dell Inspiron 13-7359 Battery Replacement: step 3, image 3 of 3
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 Battery Replacement: step 4, image 1 of 3 Dell Inspiron 13-7359 Battery Replacement: step 4, image 2 of 3 Dell Inspiron 13-7359 Battery Replacement: step 4, image 3 of 3
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
4 other people completed this guide.
Valentin Medina
697 Reputation
3 Guides authored
Baylor, Team S1-G6, Johnson Spring 2018 Member of Baylor, Team S1-G6, Johnson Spring 2018
BU-JOHNSON-S18S1G6
3 Members
5 Guides authored
One Comment
thanks for this, my daughter’s laptop now needs a new battery and while I assumed it would be easy, it’s good to get a preview.
Paul M - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 1,592
