Dell Inspiron 13-7359 Cooling Fan Replacement
  1. Dell Inspiron 13-7359 Cooling Fan Replacement, Back Cover: step 1, image 1 of 1
    • Flip your device over so the back cover is facing you.
    • Using a Phillips #0 Screwdriver, remove the ten 7mm screws holding the back cover in place.
  2. Dell Inspiron 13-7359 Cooling Fan Replacement: step 2, image 1 of 1
    • Insert a plastic opening and run it along the edge of the back cover. Do this until the entire back cover can be removed.
  3. Dell Inspiron 13-7359 Cooling Fan Replacement, Cooling Fan: step 3, image 1 of 2 Dell Inspiron 13-7359 Cooling Fan Replacement, Cooling Fan: step 3, image 2 of 2
    • Unscrew and remove the 2 of the 7mm Phillips head screws holding the cooling fan in place.
  4. Dell Inspiron 13-7359 Cooling Fan Replacement: step 4, image 1 of 1
    • Hold the cooling fan with one hand.
    • With the other hand, grab hold of the part of the copper heat sink that is attached to the cooling fan.
    • Carefully pull the cooling fan away from the attached part so that it becomes fully disconnected.
2 other people completed this guide.
Valentin Medina
697 Reputation
3 Guides authored
Baylor, Team S1-G6, Johnson Spring 2018 Member of Baylor, Team S1-G6, Johnson Spring 2018
BU-JOHNSON-S18S1G6
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 662
