Dell Inspiron 13-7359 Hard Drive Replacement
  1. Dell Inspiron 13-7359 Hard Drive Replacement, Back Cover: step 1, image 1 of 1
    • Flip your device over so the back cover is facing you.
    • Using a Phillips #0 Screwdriver, remove the ten 7mm screws holding the back cover in place.
  2. Dell Inspiron 13-7359 Hard Drive Replacement: step 2, image 1 of 1
    • Insert a plastic opening and run it along the edge of the back cover. Do this until the entire back cover can be removed.
  3. Dell Inspiron 13-7359 Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
    • Unscrew and remove the 2 of the 3mm Phillips head screws holding the hard drive in place.
  4. Dell Inspiron 13-7359 Hard Drive Replacement: step 4, image 1 of 2 Dell Inspiron 13-7359 Hard Drive Replacement: step 4, image 2 of 2
    • Lift and hold the hard drive in your left hand.
    • Use your right hand to grab hold of the black wire connector attached on the right of the hard drive.
    • Carefully pull the connector away from the hard drive to completely disconnect from the laptop.
6 other people completed this guide.
Valentin Medina
697 Reputation
3 Guides authored
Baylor, Team S1-G6, Johnson Spring 2018 Member of Baylor, Team S1-G6, Johnson Spring 2018
BU-JOHNSON-S18S1G6
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 1,985
