Dell Inspiron 13-7359 WLAN Adaptor Replacement
  1. Dell Inspiron 13-7359 WLAN Adaptor Replacement, Battery: step 1, image 1 of 1
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 WLAN Adaptor Replacement: step 2, image 1 of 1
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 WLAN Adaptor Replacement: step 3, image 1 of 3 Dell Inspiron 13-7359 WLAN Adaptor Replacement: step 3, image 2 of 3 Dell Inspiron 13-7359 WLAN Adaptor Replacement: step 3, image 3 of 3
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 WLAN Adaptor Replacement: step 4, image 1 of 3 Dell Inspiron 13-7359 WLAN Adaptor Replacement: step 4, image 2 of 3 Dell Inspiron 13-7359 WLAN Adaptor Replacement: step 4, image 3 of 3
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
  5. Dell Inspiron 13-7359 WLAN Adaptor Replacement, WLAN Adaptor: step 5, image 1 of 1
    • Unhook both of the wires attached to the WLAN adaptor.
  6. Dell Inspiron 13-7359 WLAN Adaptor Replacement: step 6, image 1 of 1
    • Remove the 3.9mm Phillips screw using Phillips #0 screwdriver.
    • Once the screw is removed, one end of the WLAN adaptor will raise up.
  7. Dell Inspiron 13-7359 WLAN Adaptor Replacement: step 7, image 1 of 1
    • Gently remove the WLAN adaptor.
Bo Yi Lim
205 Reputation
2 Guides authored
IUPUI, Team S3-G4, Harley Spring 2019 Member of IUPUI, Team S3-G4, Harley Spring 2019
IUPUI-HARLEY-S19S3G4
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 165
