Dell Inspiron 13-7370 Fan Replacement
  1. Dell Inspiron 13-7370 Fan Replacement, Fan: step 1, image 1 of 3 Dell Inspiron 13-7370 Fan Replacement, Fan: step 1, image 2 of 3 Dell Inspiron 13-7370 Fan Replacement, Fan: step 1, image 3 of 3
    • Make sure the laptop is turned off and not connected to a charging cable.
    • Using a Phillips #0 screwdriver, remove the ten (10) 2.5 mm screws fastening the bottom cover.
  2. Dell Inspiron 13-7370 Fan Replacement: step 2, image 1 of 2 Dell Inspiron 13-7370 Fan Replacement: step 2, image 2 of 2
    • Starting around the edges of the laptop, lift and remove the back cover. Apply pressure upwards, until you hear a popping noise.
    • Moving clockwise around the laptop, continue to apply pressure upwards, using your fingers or a plastic pick, until the bottom cover pops out of its locks.
  3. Dell Inspiron 13-7370 Fan Replacement: step 3, image 1 of 2 Dell Inspiron 13-7370 Fan Replacement: step 3, image 2 of 2
    • Using the Phillips #0 screwdriver, remove the four 2 mm screws.
    • Carefully disconnect the battery from the motherboard.
  4. Dell Inspiron 13-7370 Fan Replacement: step 4, image 1 of 2 Dell Inspiron 13-7370 Fan Replacement: step 4, image 2 of 2
    • Using the Phillips #0 screwdriver, remove the two 2 mm screws holding the fan in place.
  5. Dell Inspiron 13-7370 Fan Replacement: step 5, image 1 of 3 Dell Inspiron 13-7370 Fan Replacement: step 5, image 2 of 3 Dell Inspiron 13-7370 Fan Replacement: step 5, image 3 of 3
    • Lifting the fan, disconnect it from the laptop by grasping the connector (circled in red), and pulling out horizontally.
    • Do NOT pull the connecter upwards, as this may damage the socket you are pulling it out of.
  6. Dell Inspiron 13-7370 Fan Replacement: step 6, image 1 of 1
    • Remove the fan from the device.
Zayed Azam
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 18
All Time: 730
