Dell Inspiron 13-7373 Daughterboard Replacement
  1. Dell Inspiron 13-7373 Daughterboard Replacement, Back Cover: step 1, image 1 of 3 Dell Inspiron 13-7373 Daughterboard Replacement, Back Cover: step 1, image 2 of 3 Dell Inspiron 13-7373 Daughterboard Replacement, Back Cover: step 1, image 3 of 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Daughterboard Replacement, Network Card: step 2, image 1 of 1
    • Use the Phillips #00 screwdriver to remove the single screw holding in the network card.
    • Remove the network card from the laptop.
  3. Dell Inspiron 13-7373 Daughterboard Replacement, Daughterboard: step 3, image 1 of 1
    • Use the Phillips #00 screwdriver to remove the two 1mm screws holding in the daughterboard.
    • Remove the metal piece holding in the daughterboard.
    • Disconnect the two cable connectors from the daughterboard.
    • If the cables are stuck, gently wiggle them until they disconnect.
  4. Dell Inspiron 13-7373 Daughterboard Replacement: step 4, image 1 of 1
    • Remove the daughterboard.
Kristen Gismondi
84,844 Reputation
215 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,893 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 316
