Dell Inspiron 13-7373 Motherboard Replacement
  1. Dell Inspiron 13-7373 Motherboard Replacement, Back Cover: step 1, image 1 of 3 Dell Inspiron 13-7373 Motherboard Replacement, Back Cover: step 1, image 2 of 3 Dell Inspiron 13-7373 Motherboard Replacement, Back Cover: step 1, image 3 of 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Motherboard Replacement, Battery: step 2, image 1 of 1
    • Use a Phillips screwdriver to remove the four screws holding the battery in place.
  3. Dell Inspiron 13-7373 Motherboard Replacement: step 3, image 1 of 2 Dell Inspiron 13-7373 Motherboard Replacement: step 3, image 2 of 2
    • Pull the plastic tab on the battery cable to disconnect the cable from the battery.
  4. Dell Inspiron 13-7373 Motherboard Replacement: step 4, image 1 of 2 Dell Inspiron 13-7373 Motherboard Replacement: step 4, image 2 of 2
    • Remove the battery from the laptop.
  5. Dell Inspiron 13-7373 Motherboard Replacement, Fan: step 5, image 1 of 1
    • Remove the two screws holding the cover for the fan.
  6. Dell Inspiron 13-7373 Motherboard Replacement: step 6, image 1 of 1
    • Unplug the connector holding the fan’s wires.
    • Remove the fan from the laptop.
  7. Dell Inspiron 13-7373 Motherboard Replacement, Network Card: step 7, image 1 of 1
    • Use the Phillips #00 screwdriver to remove the single screw holding in the network card.
    • Remove the network card from the laptop.
  8. Dell Inspiron 13-7373 Motherboard Replacement, Daughterboard: step 8, image 1 of 1
    • Use the Phillips #00 screwdriver to remove the two 1mm screws holding in the daughterboard.
    • Remove the metal piece holding in the daughterboard.
    • Disconnect the two cable connectors from the daughterboard.
    • If the cables are stuck, gently wiggle them until they disconnect.
  9. Dell Inspiron 13-7373 Motherboard Replacement: step 9, image 1 of 1
    • Remove the daughterboard.
  10. Dell Inspiron 13-7373 Motherboard Replacement, Motherboard: step 10, image 1 of 1
    • Remove the seven 2mm screws securing the motherboard.
  11. Dell Inspiron 13-7373 Motherboard Replacement: step 11, image 1 of 3 Dell Inspiron 13-7373 Motherboard Replacement: step 11, image 2 of 3 Dell Inspiron 13-7373 Motherboard Replacement: step 11, image 3 of 3
    • Release the IO Board Cable.
    • Release the Touchpad cable.
    • Release the keyboard back-light cable.
    • Release the keyboard cable.
    • Release the eDP cable.
    • Release the dc-in cable.
    • Release the cable for the LED charging indicator by gently pulling up on the connector.
  12. Dell Inspiron 13-7373 Motherboard Replacement: step 12, image 1 of 1
    • Gently lift up on the motherboard to remove it.
John Egan
473 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 28
All Time: 1,302
