Dell Inspiron 1300 Memory Modules Replacement
    • Follow the instructions in Before Working Inside Your Computer.
    • Ground yourself by touching one of the metal connectors on the back of the computer.
    • NOTE: If you leave the area, ground yourself again when you return to the computer.
  1. Dell Inspiron 1300 Memory Modules Replacement, Loosen the Screws: step 2, image 1 of 1
    • Turn the computer over, loosen the captive screws on the memory module/Mini PCI cover, and then remove the cover.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
  2. Dell Inspiron 1300 Memory Modules Replacement, Popping up the Memory Module: step 3, image 1 of 1
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
  3. Dell Inspiron 1300 Memory Modules Replacement, Removing the Module: step 4, image 1 of 1
    • Remove the module from the connector.
  4. Dell Inspiron 1300 Memory Modules Replacement, Align the Notch: step 5, image 1 of 2 Dell Inspiron 1300 Memory Modules Replacement, Align the Notch: step 5, image 2 of 2
    • Align the notch in the module edge connector with the tab in the connector slot.
  5. Dell Inspiron 1300 Memory Modules Replacement, Installing the Memory Module: step 6, image 1 of 1
    • Slide the NEW module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
  6. Dell Inspiron 1300 Memory Modules Replacement, Replacing the Module Cover: step 7, image 1 of 1
    • Replace the memory module/Mini PCI cover and tighten the screws.
    • NOTICE: If the cover is difficult to close, remove the module and reinstall it. Forcing the cover to close may damage your computer.
  7. Dell Inspiron 1300 Memory Modules Replacement, Inserting the Battery: step 8, image 1 of 1
    • Insert the battery into the battery bay, or connect the AC adapter to your computer and an electrical outlet.
Terrence15
79,924 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
44 Members
1,996 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 311
