Dell Inspiron 13z N301z Hard-Drive Assembly Replacement
  1. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Removing the Screws: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the four screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Lifting the Connector Latch: step 2, image 1 of 1
    • Lift the connector latch and pull the pull-tab to disconnect the hard-drive cable from the connector on the system board.
  3. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Lifting the Hard-Drive Assembly: step 3, image 1 of 1
    • Lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Remove the Screws: step 4, image 1 of 1
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Lifting the Hard Drive: step 5, image 1 of 2 Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Lifting the Hard Drive: step 5, image 2 of 2
    • Lift the hard drive out of the hard-drive bracket.
  6. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Disconnecting the Interposer: step 6, image 1 of 1
    • Pull the interposer to disconnect it from the hard drive.
  7. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Connecting the Interposer: step 7, image 1 of 1
    • Connect the interposer to the NEW hard drive.
  8. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Placing the Hard-Drive: step 8, image 1 of 2 Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Placing the Hard-Drive: step 8, image 2 of 2
    • Place the hard drive in the hard-drive bracket.
  9. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Replace the Screws: step 9, image 1 of 1
    • Replace the four screws the hard-drive bracket to the hard drive.
  10. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Placing the Hard-Drive Assembly: step 10, image 1 of 1
    • Place the hard-drive assembly in the computer base.
  11. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Sliding the Hard-Drive Cable: step 11, image 1 of 1
    • Slide the hard-drive cable into the connector on the system board and press down on the latch to secure the hard-drive cable.
  12. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Replace the Screws: step 12, image 1 of 1
    • Replace the four screws that secure the hard-drive assembly to the computer base.
Finish Line
Terrence15
79,243 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 217
