Dell Inspiron 14 3459 Display Assembly Replacement
  1. Dell Inspiron 14 3459 Display Assembly Replacement, Sliding the Antenna Cables: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Close the display and turn the computer over.
    • Slide the antenna cables into the slot on the computer base.
  2. Dell Inspiron 14 3459 Display Assembly Replacement, Disconnecting the I/O Board Cable: step 2, image 1 of 2 Dell Inspiron 14 3459 Display Assembly Replacement, Disconnecting the I/O Board Cable: step 2, image 2 of 2
    • Turn the computer over and open the display.
    • Open the latch and disconnect the I/O-board cable from the I/O board.
  3. Dell Inspiron 14 3459 Display Assembly Replacement, Removing the Board Cable: step 3, image 1 of 1
    • Remove the I/O-board cable from the computer base.
  4. Dell Inspiron 14 3459 Display Assembly Replacement, Remove the Antenna Cables: step 4, image 1 of 1
    • Note the antenna cable routing and remove the antenna cables from the routing guides on the computer base.
  5. Dell Inspiron 14 3459 Display Assembly Replacement, Note the Routing: step 5, image 1 of 1
    • Note the display cable routing and remove the cable from its routing guides on the computer base.
  6. Dell Inspiron 14 3459 Display Assembly Replacement, Remove the Screws: step 6, image 1 of 1
    • Remove the screws that secure the display hinges to the computer base.
  7. Dell Inspiron 14 3459 Display Assembly Replacement, Lift the Display Assembly: step 7, image 1 of 1
    • Lift the display assembly off the computer base.
  8. Dell Inspiron 14 3459 Display Assembly Replacement, Align the Screw Holes: step 8, image 1 of 1
    • Align the screw holes on the display hinges with the screw holes on the computer base.
  9. Dell Inspiron 14 3459 Display Assembly Replacement, Replace the Screws: step 9, image 1 of 1
    • Replace the screws that secure the display hinges to the computer base.
  10. Dell Inspiron 14 3459 Display Assembly Replacement, Route the Display Cable: step 10, image 1 of 1
    • Route the display cable through the routing guides on the computer base.
  11. Dell Inspiron 14 3459 Display Assembly Replacement, Route the Antenna Cables: step 11, image 1 of 1
    • Route the antenna cables through the routing guides on the computer base and slide the antenna cables through the slot on the computer base.
  12. Dell Inspiron 14 3459 Display Assembly Replacement, Sliding the I/O Board Cable: step 12, image 1 of 1
    • Slide the I/O-board cable into the I/O board and close the latch to secure the cable.
Finish Line
Terrence15
79,243 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 621
