Dell Inspiron 14 3459 Hard Drive Replacement
  1. Dell Inspiron 14 3459 Hard Drive Replacement, Remove the Screws: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 14 3459 Hard Drive Replacement, Disconnect the Hard Drive Cable: step 2, image 1 of 2 Dell Inspiron 14 3459 Hard Drive Replacement, Disconnect the Hard Drive Cable: step 2, image 2 of 2
    • Open the latch and disconnect the hard-drive cable from the system board.
  3. Dell Inspiron 14 3459 Hard Drive Replacement, Lifting the Hard-Drive Assembly: step 3, image 1 of 1
    • Lift the hard-drive assembly off the computer base.
  4. Dell Inspiron 14 3459 Hard Drive Replacement, Remove the Screws: step 4, image 1 of 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 14 3459 Hard Drive Replacement, Lifting the Hard-Drive Bracket: step 5, image 1 of 1
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 14 3459 Hard Drive Replacement, Disconnecting the Interposer: step 6, image 1 of 1
    • Disconnect the interposer from the hard drive.
  7. Dell Inspiron 14 3459 Hard Drive Replacement, Connecting the Interposer: step 7, image 1 of 1
    • Connect the interposer to the NEW hard drive.
  8. Dell Inspiron 14 3459 Hard Drive Replacement, Align the Screw Holes: step 8, image 1 of 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  9. Dell Inspiron 14 3459 Hard Drive Replacement, Replace the Screws: step 9, image 1 of 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  10. Dell Inspiron 14 3459 Hard Drive Replacement, Align the Screw Holes: step 10, image 1 of 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  11. Dell Inspiron 14 3459 Hard Drive Replacement, Replace the Screws: step 11, image 1 of 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
  12. Dell Inspiron 14 3459 Hard Drive Replacement, Securing the Hard Drive Cable: step 12, image 1 of 2 Dell Inspiron 14 3459 Hard Drive Replacement, Securing the Hard Drive Cable: step 12, image 2 of 2
    • Slide the hard-drive cable into the system board and close the latch to secure the cable.
Finish Line
Terrence15
79,243 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 1,274
