Dell Inspiron 14 3467 Base Cover Replacement
  1. Dell Inspiron 14 3467 Base Cover Replacement, Turning over the Computer: step 1, image 1 of 1
  2. Dell Inspiron 14 3467 Base Cover Replacement, Remove the Screws: step 2, image 1 of 1
    • Remove the eight screws that secure the base cover to the palm-rest assembly.
  3. Dell Inspiron 14 3467 Base Cover Replacement, Removing the Screws: step 3, image 1 of 1
    • Remove the two screws that secure the base cover to the palm-rest assembly.
  4. Dell Inspiron 14 3467 Base Cover Replacement, Removing the screws: step 4, image 1 of 1
    • Remove the three screws that secure the base cover to the palm-rest assembly.
  5. Dell Inspiron 14 3467 Base Cover Replacement, Turning the Computer over: step 5, image 1 of 1
    • Turn the computer over, and open the display.
  6. Dell Inspiron 14 3467 Base Cover Replacement, Removing the Screws: step 6, image 1 of 1
  7. Dell Inspiron 14 3467 Base Cover Replacement, Disconnecting the Optical-Drive Cable: step 7, image 1 of 1
    • Open the latch, and disconnect the optical-drive cable from the system board.
  8. Dell Inspiron 14 3467 Base Cover Replacement, Turning the Computer Over: step 8, image 1 of 1
    • Close the display, and turn the computer over
  9. Dell Inspiron 14 3467 Base Cover Replacement, Prying the Base Cover: step 9, image 1 of 1
    • Using a plastic scribe, pry the base cover off the palm-rest assembly.
  10. Dell Inspiron 14 3467 Base Cover Replacement, Lifting the Base Cover: step 10, image 1 of 1
    • Lift the base cover off the palm-rest assembly.
  11. Dell Inspiron 14 3467 Base Cover Replacement, Release the Optical-Drive Interposer: step 11, image 1 of 1
    • Release the optical-drive interposer from the tabs, and remove it from the base cover.
  12. Dell Inspiron 14 3467 Base Cover Replacement, Sliding the Optical-Drive: step 12, image 1 of 1
    • Slide the optical-drive interposer into the tabs on the NEW base cover and snap it into place.
  13. Dell Inspiron 14 3467 Base Cover Replacement, Placing the Base Cover: step 13, image 1 of 1
    • Place the base cover on the palm-rest assembly and route the optical-drive cable through the slot on the palm-rest assembly.
  14. Dell Inspiron 14 3467 Base Cover Replacement, Sliding the Tabs: step 14, image 1 of 1
    • Slide the tabs on the base cover into the slots on the palm-rest assembly, and snap the base cover into place.
  15. Dell Inspiron 14 3467 Base Cover Replacement, Sliding the Optical-Drive Cable: step 15, image 1 of 1
    • Slide the optical-drive cable into the connector on the system board and press down the latch to secure the cable.
  16. Dell Inspiron 14 3467 Base Cover Replacement, Placing the Screws: step 16, image 1 of 1
    • Replace the three screws (M2x5) that secure the base cover to the palm-rest assembly.
  17. Dell Inspiron 14 3467 Base Cover Replacement, Turning over the Computer: step 17, image 1 of 1
    • Close the display, and turn the computer over.
  18. Dell Inspiron 14 3467 Base Cover Replacement, Replacing the Screws: step 18, image 1 of 1
    • Replace the three screws (M2x2) that secure the base cover to the palm-rest assembly.
  19. Dell Inspiron 14 3467 Base Cover Replacement, Replacing the Screws: step 19, image 1 of 1
    • Replace the two screws (M2x5) that secure the base cover to the palm-rest assembly.
  20. Dell Inspiron 14 3467 Base Cover Replacement, Replacing the Screws: step 20, image 1 of 1
    • Replace the eight screws that secure the base cover to the palm-rest assembly.
Finish Line
darrius
5,213 Reputation
30 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 12
All Time: 2,017
