Dell Inspiron 14 3467 Hard-Drive Replacement
  1. Dell Inspiron 14 3467 Hard-Drive  Replacement, Disconnecting The Hard-Drive: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in [http://n Before working inside your computer.]
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Open the latch, and disconnect the hard-drive cable from the connector on the system board.
  2. Dell Inspiron 14 3467 Hard-Drive  Replacement, Removing The Two Screws: step 2, image 1 of 1
    • Remove the two screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
  3. Dell Inspiron 14 3467 Hard-Drive  Replacement, Lifting The Hard-Drive: step 3, image 1 of 1
    • Lift the hard-drive assembly along with its cable off the palm-rest assembly.
  4. Dell Inspiron 14 3467 Hard-Drive  Replacement, Removing The Four Screws: step 4, image 1 of 1
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the harddrive assembly.
  5. Dell Inspiron 14 3467 Hard-Drive  Replacement, Removing The Hard-Drive Bracket: step 5, image 1 of 1
    • Lift the hard-drive assembly off the hard-drive bracket.
  6. Dell Inspiron 14 3467 Hard-Drive  Replacement, Disconnecting The Interposer: step 6, image 1 of 1
    • Disconnect the interposer from the hard drive.
  7. Dell Inspiron 14 3467 Hard-Drive  Replacement, Connecting The Interposer: step 7, image 1 of 1
    • Connect the interposer to the NEW hard drive
  8. Dell Inspiron 14 3467 Hard-Drive  Replacement, Aligning The Screws: step 8, image 1 of 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard-drive assembly.
  9. Dell Inspiron 14 3467 Hard-Drive  Replacement, Screwing The Bracket To Hard-Drive: step 9, image 1 of 1
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the harddrive assembly.
  10. Dell Inspiron 14 3467 Hard-Drive  Replacement, Securing To Hard-Drive Assembly: step 10, image 1 of 1
    • Replace the two screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
darrius
5,213 Reputation
30 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 3,180
