Dell Inspiron 14 5100 Hard Drive Replacement
  1. Dell Inspiron 14 5100 Hard Drive Replacement, Dell Inspiron 14 5100 Disassembly: step 1, image 1 of 3 Dell Inspiron 14 5100 Hard Drive Replacement, Dell Inspiron 14 5100 Disassembly: step 1, image 2 of 3 Dell Inspiron 14 5100 Hard Drive Replacement, Dell Inspiron 14 5100 Disassembly: step 1, image 3 of 3
    • Make sure to disconnect the power source to the device.
    • Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
    • There are 2 sets of screws.
    • Remove the 3 captive screws.
    • Remove the 6M2*6 screws.
  2. Dell Inspiron 14 5100 Hard Drive Replacement: step 2, image 1 of 2 Dell Inspiron 14 5100 Hard Drive Replacement: step 2, image 2 of 2
    • Pry open the laptop to separate the base cover from the keyboard assembly.
    • You may use your fingertips or use plastic opening tools.
  3. Dell Inspiron 14 5100 Hard Drive Replacement, Battery: step 3, image 1 of 2 Dell Inspiron 14 5100 Hard Drive Replacement, Battery: step 3, image 2 of 2
    • Remove the four Phillips #0 screws securing the battery to the keyboard assembly.
  4. Dell Inspiron 14 5100 Hard Drive Replacement: step 4, image 1 of 3 Dell Inspiron 14 5100 Hard Drive Replacement: step 4, image 2 of 3 Dell Inspiron 14 5100 Hard Drive Replacement: step 4, image 3 of 3
    • Peel off the tape securing the battery cable to the battery cable connector.
    • Disconnect and remove the old battery.
  5. Dell Inspiron 14 5100 Hard Drive Replacement, Hard Drive: step 5, image 1 of 1
    • Unplug the connectors from the hard drive and slide it out of its slot.
0 Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 75
All Time: 2,217
