Dell Inspiron 14 5100 Power Adapter Port Replacement
  1. Dell Inspiron 14 5100 Power Adapter Port Replacement, Dell Inspiron 14 5100 Disassembly: step 1, image 1 of 3 Dell Inspiron 14 5100 Power Adapter Port Replacement, Dell Inspiron 14 5100 Disassembly: step 1, image 2 of 3 Dell Inspiron 14 5100 Power Adapter Port Replacement, Dell Inspiron 14 5100 Disassembly: step 1, image 3 of 3
    • Make sure to disconnect the power source to the device.
    • Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
    • There are 2 sets of screws.
    • Remove the 3 captive screws.
    • Remove the 6M2*6 screws.
  2. Dell Inspiron 14 5100 Power Adapter Port Replacement: step 2, image 1 of 2 Dell Inspiron 14 5100 Power Adapter Port Replacement: step 2, image 2 of 2
    • Pry open the laptop to separate the base cover from the keyboard assembly.
    • You may use your fingertips or use plastic opening tools.
  3. Dell Inspiron 14 5100 Power Adapter Port Replacement, Power Adapter Port: step 3, image 1 of 2 Dell Inspiron 14 5100 Power Adapter Port Replacement, Power Adapter Port: step 3, image 2 of 2
    • Disconnect the power-adapter port cable from the motherboard.
  4. Dell Inspiron 14 5100 Power Adapter Port Replacement: step 4, image 1 of 2 Dell Inspiron 14 5100 Power Adapter Port Replacement: step 4, image 2 of 2
    • Remove the two screws securing the power adapter port to the keyboard assembly using the Phillips #0 screwdriver.
  5. Dell Inspiron 14 5100 Power Adapter Port Replacement: step 5, image 1 of 1
    • Remove the power adapter port and remove it from the device.
2 other people completed this guide.
0 Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 41
All Time: 3,119
