Dell Inspiron 14 5443 Hard Drive Replacement
  1. Dell Inspiron 14 5443 Hard Drive Replacement, Removing screws: step 1, image 1 of 1
    • Remove the screws that secure the hard-drive assembly to the base frame.
  2. Dell Inspiron 14 5443 Hard Drive Replacement, Gently Lift Hard-Drive: step 2, image 1 of 1
    • Gently lift the hard-drive assembly out of the base frame and disconnect the hard-drive cable from the hard drive.
  3. Dell Inspiron 14 5443 Hard Drive Replacement, Removing Screws From Bracket: step 3, image 1 of 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  4. Dell Inspiron 14 5443 Hard Drive Replacement, Lifting Bracket: step 4, image 1 of 1
    • Lift the hard-drive bracket off the hard drive
  5. Dell Inspiron 14 5443 Hard Drive Replacement, Placing Bracket: step 5, image 1 of 1
    • Place the hard-drive bracket on the NEW hard drive.
  6. Dell Inspiron 14 5443 Hard Drive Replacement, Aligning the Screws: step 6, image 1 of 1
    • Align the screw holes on the hard drive-bracket with the screw holes on the hard drive.
  7. Dell Inspiron 14 5443 Hard Drive Replacement, Replace the Screws: step 7, image 1 of 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 14 5443 Hard Drive Replacement, Connecting Hard-Drive To Cable: step 8, image 1 of 1
    • Connect the hard-drive cable to the hard drive.
  9. Dell Inspiron 14 5443 Hard Drive Replacement, Placing the Hard-Drive: step 9, image 1 of 1
    • Place the hard-drive assembly in the base frame and align the screw holes on the hard-drive assembly with the screw holes on the base frame.
  10. Dell Inspiron 14 5443 Hard Drive Replacement, Securing the Screws: step 10, image 1 of 1
    • Replace the screws that secure the hard-drive assembly to the base frame.
Finish Line
darrius
5,213 Reputation
30 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 241
