Dell Inspiron 14 M4010 Hard Drive Replacement
  1. Dell Inspiron 14 M4010 Hard Drive Replacement, Remove the Screws: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • WARNING: If you remove the hard drive from the computer when the drive is hot, do not touch the metal housing of the hard drive.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the two screws that secure the hard-drive assembly to the system board.
  2. Dell Inspiron 14 M4010 Hard Drive Replacement, Disconnecting the Hard-Drive Assembly: step 2, image 1 of 1
    • Slide the hard-drive assembly to disconnect it from the connector on the system board.
  3. Dell Inspiron 14 M4010 Hard Drive Replacement, Lifting the Hard-Drive Assembly: step 3, image 1 of 1
    • Lift the hard-drive assembly away from the system board.
  4. Dell Inspiron 14 M4010 Hard Drive Replacement, Remove the Screws: step 4, image 1 of 1
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 14 M4010 Hard Drive Replacement, Lifting the Hard-Drive Bracket: step 5, image 1 of 1
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 14 M4010 Hard Drive Replacement, Align the Screws: step 6, image 1 of 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive and replace the four screws.
  7. Dell Inspiron 14 M4010 Hard Drive Replacement, Connecting the Hard-Drive Assembly: step 7, image 1 of 1
    • Slide and push the hard-drive assembly to connect it to connector on the system board.
  8. Dell Inspiron 14 M4010 Hard Drive Replacement, Replace the Screws: step 8, image 1 of 1
    • Replace the two screws that secure the hard-drive assembly to the system board.
Finish Line
Terrence15
79,243 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 66
