Dell Inspiron 14 N4030 Display Assembly Replacement
  1. Dell Inspiron 14 N4030 Display Assembly Replacement, Disconnecting the Display Cable: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Disconnect the display cable from the connector on the system board.
  2. Dell Inspiron 14 N4030 Display Assembly Replacement, Remove the Screws: step 2, image 1 of 1
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  3. Dell Inspiron 14 N4030 Display Assembly Replacement, Removing the Display Assembly: step 3, image 1 of 1
    • Lift and remove the display assembly out of the computer base.
  4. Dell Inspiron 14 N4030 Display Assembly Replacement, Placing the Display Assembly: step 4, image 1 of 1
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  5. Dell Inspiron 14 N4030 Display Assembly Replacement, Connecting the Display Cable: step 5, image 1 of 1
    • Connect the display cable to the connector on the system board.
Finish Line
Terrence15
79,555 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,985 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 648
