Dell Inspiron 14 N4030 Hard Drive Replacement
  1. Dell Inspiron 14 N4030 Hard Drive Replacement, Remove the Screws: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 14 N4030 Hard Drive Replacement, Sliding the Assembly: step 2, image 1 of 1
    • Slide the hard-drive assembly out of the hard-drive compartment.
  3. Dell Inspiron 14 N4030 Hard Drive Replacement, Remove the Screws: step 3, image 1 of 1
    • Remove the two screws that secure the hard-drive bezel to the hard drive.
  4. Dell Inspiron 14 N4030 Hard Drive Replacement, Removing the Hard Drive: step 4, image 1 of 1
    • Pull the hard-drive bezel away from the hard drive.
  5. Dell Inspiron 14 N4030 Hard Drive Replacement, Align the Screw Holes: step 5, image 1 of 1
    • Align the screw holes on the NEW hard-drive bezel with the screw holes on the hard drive and replace the two screws.
  6. Dell Inspiron 14 N4030 Hard Drive Replacement, Sliding the Hard-Drive Assembly: step 6, image 1 of 1
    • Slide the hard-drive assembly into the hard-drive compartment until it is fully seated.
  7. Dell Inspiron 14 N4030 Hard Drive Replacement, Replace the Screws: step 7, image 1 of 1
    • Replace the two screws that secure the hard-drive assembly to the computer base.
Finish Line
2 other people completed this guide.
Terrence15
79,555 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,985 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 1,142
