Dell Inspiron 14 N4050 Hard Drive Replacement
  1. Dell Inspiron 14 N4050 Hard Drive Replacement, Sliding the Hard-Drive Assembly: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Slide the hard-drive assembly to the left to disconnect it from the connector on the system board.
  2. Dell Inspiron 14 N4050 Hard Drive Replacement, Lifting the Hard-Drive Assembly: step 2, image 1 of 1
    • Lift the hard-drive assembly out of the computer base.
  3. Dell Inspiron 14 N4050 Hard Drive Replacement, Remove the Screws: step 3, image 1 of 1
    • Remove the two screws that secure the hard-drive bracket to the hard drive.
  4. Dell Inspiron 14 N4050 Hard Drive Replacement, Lifting the Hard-Drive Bracket: step 4, image 1 of 1
    • Lift the hard-drive bracket away from the hard drive.
  5. Dell Inspiron 14 N4050 Hard Drive Replacement, Placing the Hard-Drive Bracket: step 5, image 1 of 1
    • Place the hard-drive bracket on the NEW hard drive.
  6. Dell Inspiron 14 N4050 Hard Drive Replacement, Replace the Screws: step 6, image 1 of 1
    • Replace the two screws that secure the hard-drive bracket to the hard drive.
  7. Dell Inspiron 14 N4050 Hard Drive Replacement, Placing the Hard-Drive Assembly: step 7, image 1 of 1
    • Place the hard-drive assembly on the computer base.
  8. Dell Inspiron 14 N4050 Hard Drive Replacement, Push the Hard Drive Assembly: step 8, image 1 of 1
    • Push the hard-drive assembly towards the right to connect it to the connector on the system board.
Finish Line
Terrence15
79,243 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 1,597
