Dell Inspiron 14-5415 Fan Replacement
  1. Dell Inspiron 14-5415 Fan Replacement, Back Cover: step 1, image 1 of 1
    • Close the lid and turn the laptop over to access the back cover.
  2. Dell Inspiron 14-5415 Fan Replacement: step 2, image 1 of 1
    • Remove the five 4 mm screws from the back of the laptop using a Phillips #0 screwdriver.
    • Loosen the two remaining captive screws using a Phillips #0 screwdriver.
    • Captive screws tend to have a slightly larger head than normal screws, so it is important to use the correct size screwdriver to avoid damaging the screw or the device.
  3. Dell Inspiron 14-5415 Fan Replacement, Fan: step 3, image 1 of 3 Dell Inspiron 14-5415 Fan Replacement, Fan: step 3, image 2 of 3 Dell Inspiron 14-5415 Fan Replacement, Fan: step 3, image 3 of 3
    • To access the Dell Inspiron fan flip the device upside down.
    • When identifying parts in the device, the Dell logo on the battery pack should be upright.
    • The fan is fastened at the top left hand corner of the device.
    • Remove two 4 mm screws using a Phillips #00 screwdriver.
  4. Dell Inspiron 14-5415 Fan Replacement: step 4, image 1 of 3 Dell Inspiron 14-5415 Fan Replacement: step 4, image 2 of 3 Dell Inspiron 14-5415 Fan Replacement: step 4, image 3 of 3
    • Gently pull on the fan adapter until it is disconnected from the port.
    • Don't pull too hard on the adapter as this may damage the part.
    • Carefully lift the fan out of the slot.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 314
