Dell Inspiron 14-5447 Battery Replacement
  1. Dell Inspiron 14-5447 Battery Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop upside down to access the battery.
  2. Dell Inspiron 14-5447 Battery Replacement: step 2, image 1 of 2 Dell Inspiron 14-5447 Battery Replacement: step 2, image 2 of 2
    • Remove the two black 5.70mm Phillips#0 screws on the case's back.
    • Insert a plastic opening tool into the small slit, centered between the removed screws, and pry open the back cover
  3. Dell Inspiron 14-5447 Battery Replacement: step 3, image 1 of 2 Dell Inspiron 14-5447 Battery Replacement: step 3, image 2 of 2
    • Remove the two 5.70mm Phillips #0 screws that secure the battery in place on its left side .
    • Treat the battery with care - puncturing or bending may cause damage to the battery and may result in fire or injury.
  4. Dell Inspiron 14-5447 Battery Replacement: step 4, image 1 of 2 Dell Inspiron 14-5447 Battery Replacement: step 4, image 2 of 2
    • Use the black, plastic flap on the left side to pull the battery out.
    • Slowly lift the flap up and the battery should slide out.
4 other people completed this guide.
0 Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 24
All Time: 3,068
