Dell Inspiron 14-7437 Base Cover Replacement
  1. Dell Inspiron 14-7437 Base Cover Replacement, Base Cover: step 1, image 1 of 2 Dell Inspiron 14-7437 Base Cover Replacement, Base Cover: step 1, image 2 of 2
    • Power off your Dell Inspiron 14-7437 before disassembling.
    • Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
    • The two 4.5 mm screws in the center under the rubber mount cannot be removed, but can be loosened.
  2. Dell Inspiron 14-7437 Base Cover Replacement: step 2, image 1 of 2 Dell Inspiron 14-7437 Base Cover Replacement: step 2, image 2 of 2
    • Pry open the back cover using a spudger and slide it along the under the cover.
Travis Connolly
330 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 1,706
