Dell Inspiron 14-7437 Battery Replacement
  1. Dell Inspiron 14-7437 Battery Replacement, Base Cover: step 1, image 1 of 2 Dell Inspiron 14-7437 Battery Replacement, Base Cover: step 1, image 2 of 2
    • Power off your Dell Inspiron 14-7437 before disassembling.
    • Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
    • The two 4.5 mm screws in the center under the rubber mount cannot be removed, but can be loosened.
  2. Dell Inspiron 14-7437 Battery Replacement: step 2, image 1 of 2 Dell Inspiron 14-7437 Battery Replacement: step 2, image 2 of 2
    • Pry open the back cover using a spudger and slide it along the under the cover.
  3. Dell Inspiron 14-7437 Battery Replacement, Battery: step 3, image 1 of 2 Dell Inspiron 14-7437 Battery Replacement, Battery: step 3, image 2 of 2
    • Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
  4. Dell Inspiron 14-7437 Battery Replacement: step 4, image 1 of 1
    • Disconnect the ribbon cables from the motherboard.
  5. Dell Inspiron 14-7437 Battery Replacement: step 5, image 1 of 1
    • Lift up and remove the Lithium-Polymer Battery.
3 other people completed this guide.
Travis Connolly
330 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 4,252
