Introduction
In this guide, we will be showing you how to remove and replace the Display Assembly.
Remove the mylar tapes and then remove the two screws from the back of the computer.
Pull the display cable tab to disconnect the display cable from the system board connector.
Make note of the cable routing and carefully dislodge the WLAN antenna cables and the rest of the cables from their routing guides. Pull the cables away, so that they are clear of the palm rest.
Place the NEW display assembly in place and replace the two screws on each side of the display hinges.
Re-route and connect the display cable to the connector on the system board.
Carefully route the WLAN antenna cables into their routing guides on the palm rest and through the computer base.
