Dell Inspiron 1420 Heat Sink Replacement
  1. Dell Inspiron 1420 Heat Sink Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 1420 Heat Sink Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 1420 Heat Sink Replacement, Battery: step 1, image 3 of 3
    • Slide the two tabs to release the battery.
    • Pull the battery out.
  2. Dell Inspiron 1420 Heat Sink Replacement, Remove the Panel: step 2, image 1 of 3 Dell Inspiron 1420 Heat Sink Replacement, Remove the Panel: step 2, image 2 of 3 Dell Inspiron 1420 Heat Sink Replacement, Remove the Panel: step 2, image 3 of 3
    • Using a Phillips #00 screwdriver, remove the three 5mm screws.
    • Lift the panel and set it aside.
  3. Dell Inspiron 1420 Heat Sink Replacement: step 3, image 1 of 3 Dell Inspiron 1420 Heat Sink Replacement: step 3, image 2 of 3 Dell Inspiron 1420 Heat Sink Replacement: step 3, image 3 of 3
    • Remove the four screws (3mm) securing the heat sink to the CPU.
    • Lift the Heat sink out of the laptop.
David Nunez
46 Reputation
1 Guide authored
USF Tampa, Team 2-4, Blackwell Fall 2014 Member of USF Tampa, Team 2-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G4
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 972
