Dell Inspiron 1420 Memory Module Replacement
  1. Dell Inspiron 1420 Memory Module Replacement, Loosen the Screws: step 1, image 1 of 1
    • Follow the procedures in Before You Begin.
    • Turn the computer over.
    • Loosen the captive screws from the memory module cover.
  2. Dell Inspiron 1420 Memory Module Replacement, Lifting the Cover: step 2, image 1 of 1
    • Lift the memory module cover and set it aside.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
  3. Dell Inspiron 1420 Memory Module Replacement, Popping up the Memory Module: step 3, image 1 of 1
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
  4. Dell Inspiron 1420 Memory Module Replacement, Removing the Module: step 4, image 1 of 1
    • Remove the module from the connector.
  5. Dell Inspiron 1420 Memory Module Replacement, Align the Notch: step 5, image 1 of 1
    • Align the notch in the module edge connector with the tab in the connector slot.
  6. Dell Inspiron 1420 Memory Module Replacement, Sliding the Module: step 6, image 1 of 1
    • Slide the module firmly into the slot at a 30-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot. No error message indicates this failure.
  7. Dell Inspiron 1420 Memory Module Replacement, Replace the Module Cover: step 7, image 1 of 2 Dell Inspiron 1420 Memory Module Replacement, Replace the Module Cover: step 7, image 2 of 2
    • Replace the memory module cover and tighten the three captive screws.
Finish Line
Terrence15
79,918 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
44 Members
1,996 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 361
