Dell Inspiron 1420 RAM Replacement
  1. Dell Inspiron 1420 RAM Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 1420 RAM Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 1420 RAM Replacement, Battery: step 1, image 3 of 3
    • Slide the two tabs to release the battery.
    • Pull the battery out.
  2. Dell Inspiron 1420 RAM Replacement, Removing the panel: step 2, image 1 of 3 Dell Inspiron 1420 RAM Replacement, Removing the panel: step 2, image 2 of 3 Dell Inspiron 1420 RAM Replacement, Removing the panel: step 2, image 3 of 3
    • Using a Phillips #00 screwdriver, remove the three 2.5mm screws from the panel.
    • Pull back the panel and set it aside.
  3. Dell Inspiron 1420 RAM Replacement, Removing the RAM: step 3, image 1 of 3 Dell Inspiron 1420 RAM Replacement, Removing the RAM: step 3, image 2 of 3 Dell Inspiron 1420 RAM Replacement, Removing the RAM: step 3, image 3 of 3
    • Spread apart the securing clips on both ends of the chip until the module pops out.
    • Remove the RAM from the connector.
    • These represent the clips of a second module
2 other people completed this guide.
Shaun Dinsmore
81 Reputation
2 Guides authored
USF Tampa, Team 2-4, Blackwell Fall 2014 Member of USF Tampa, Team 2-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G4
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 1,131
