Dell Inspiron 1425 Hard-Drive Assembly Replacement
  1. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Remove the Screw: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the screw that secures the hard-drive assembly to the system board.
  2. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Sliding the Hard Drive Assembly: step 2, image 1 of 1
    • Slide the hard-drive assembly in the direction shown in the illustration to disconnect it from the connector on the system board.
  3. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Lifting the Hard-Drive Assembly: step 3, image 1 of 1
    • Lift the hard-drive assembly off the system board.
  4. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Remove the Screws: step 4, image 1 of 1
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Lifting the Hard Drive: step 5, image 1 of 2 Dell Inspiron 1425 Hard-Drive Assembly Replacement, Lifting the Hard Drive: step 5, image 2 of 2
    • Lift the hard drive away from the hard-drive bracket.
  6. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Placing the Hard Drive: step 6, image 1 of 1
    • Place the hard drive in the hard-drive bracket.
  7. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Replace the Screws: step 7, image 1 of 1
    • Replace the four screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Placing the Hard Drive Assembly: step 8, image 1 of 1
    • Place the NEW hard-drive assembly on the system board.
  9. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Slding the Hard-Drive Assembly: step 9, image 1 of 1
    • Slide the hard-drive assembly to connect it to the connector on the system board.
  10. Dell Inspiron 1425 Hard-Drive Assembly Replacement, Replace the Screw: step 10, image 1 of 1
    • Replace the screw that secures the hard-drive assembly to the system board.
Finish Line
Terrence15
79,522 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,985 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 130
