Dell Inspiron 14R Hard Drive Assembly Replacement
  1. Dell Inspiron 14R Hard Drive Assembly Replacement, Remove the Screw: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the screw that secures the hard-drive assembly to the system board.
  2. Dell Inspiron 14R Hard Drive Assembly Replacement, Sliding the Hard-Drive Assembly: step 2, image 1 of 1
    • Slide the hard-drive assembly in the direction shown in the illustration to disconnect it from the connector on the system board.
  3. Dell Inspiron 14R Hard Drive Assembly Replacement, Lifting the Hard-Drive Assembly: step 3, image 1 of 1
    • Lift the hard-drive assembly off the system board.
  4. Dell Inspiron 14R Hard Drive Assembly Replacement, Remove the Screws: step 4, image 1 of 1
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 14R Hard Drive Assembly Replacement, Lifting the Hard Drive: step 5, image 1 of 1
    • Lift the hard drive away from the hard-drive bracket.
  6. Dell Inspiron 14R Hard Drive Assembly Replacement, Placing the Hard Drive: step 6, image 1 of 1
    • Place the NEW hard drive in the hard-drive bracket.
  7. Dell Inspiron 14R Hard Drive Assembly Replacement, Replace the Screws: step 7, image 1 of 1
    • Replace the four screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 14R Hard Drive Assembly Replacement, Placing the Hard-Drive Assembly: step 8, image 1 of 1
    • Place the hard-drive assembly on the system board.
  9. Dell Inspiron 14R Hard Drive Assembly Replacement, Sliding the Hard Drive Assembly: step 9, image 1 of 1
    • Slide the hard-drive assembly to connect it to the connector on the system board.
  10. Dell Inspiron 14R Hard Drive Assembly Replacement, Replace the Screw: step 10, image 1 of 1
    • Replace the screw that secures the hard-drive assembly to the system board.
    • CAUTION: Before turning on the computer, replace all screws and ensure that no stray screws remain inside the computer. Failure to do so may result in damage to the computer.
Finish Line
Terrence15
79,309 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,984 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 189
