Dell Inspiron 14R SE 7420 Hard Drive Replacement
  1. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Disconnecting the Hard Drive Cable: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is On or in Sleep state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Pull the pull-tab to disconnect the hard-drive cable from the system-board connector.
  2. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Remove the Screws: step 2, image 1 of 1
    • Remove the screws that secure the hard-drive assembly to the computer base.
  3. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Removing the Cable: step 3, image 1 of 1
    • Make a note of the hard-drive cable routing and remove the cable from the routing guides.
  4. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Lifting the Hard-Drive Assembly: step 4, image 1 of 1
    • Lift the hard-drive assembly along with its cable away from the computer base.
  5. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Pull the Interposer: step 5, image 1 of 1
    • Pull the interposer to disconnect the hard-drive cable from the hard-drive.
  6. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Remove the Screws: step 6, image 1 of 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  7. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Sliding the Hard Drive: step 7, image 1 of 1
    • Slide the hard-drive off the hard-drive bracket.
  8. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Align the Screw Holes: step 8, image 1 of 1
    • Align the screw holes on the NEW hard-drive bracket with the screw holes on the hard drive.
  9. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Replace the Screws: step 9, image 1 of 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  10. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Connecting the Interposer: step 10, image 1 of 1
    • Connect the hard-drive cable interposer to the hard drive.
  11. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Place the Hard-Drive Assembly: step 11, image 1 of 1
    • Place the hard-drive assembly in the hard-drive bay on the computer base.
  12. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Replace the Screws: step 12, image 1 of 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
  13. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Routing the Hard-Drive Cable: step 13, image 1 of 1
    • Route the hard-drive cable through the routing guides on the computer base.
  14. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Connecting the Hard Drive Cable: step 14, image 1 of 1
    • Connect the hard-drive cable to the system-board connector.
Finish Line
Terrence15
79,243 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 240
