Dell Inspiron 14R-5421 RAM Replacement
  1. Dell Inspiron 14R-5421 RAM Replacement, Battery: step 1, image 1 of 1
    • Push the two sliders away from the battery towards the outer edges.
  2. Dell Inspiron 14R-5421 RAM Replacement: step 2, image 1 of 2 Dell Inspiron 14R-5421 RAM Replacement: step 2, image 2 of 2
    • Remove the battery when it pops up.
  3. Dell Inspiron 14R-5421 RAM Replacement, RAM: step 3, image 1 of 1
    • Unscrew the cover from the laptop using a Phillips #0 screwdriver.
    • Remove the cover hiding the internal components by sliding it down.
  4. Dell Inspiron 14R-5421 RAM Replacement: step 4, image 1 of 1
    • Lift the ram module up then pull it out of its slot.
    • Be sure to place the new ram module back into the same slot. Only put a module into slot DIMM B if you have a second working module you want to use.
Jared paiva
489 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 383
