Dell Inspiron 14z Memory module Replacement
  1. Dell Inspiron 14z Memory module Replacement, Memory module: step 1, image 1 of 3 Dell Inspiron 14z Memory module Replacement, Memory module: step 1, image 2 of 3 Dell Inspiron 14z Memory module Replacement, Memory module: step 1, image 3 of 3
    • Here is a Dell Inspiron 14z N411z that is going to get a new memory module.
    • On the back side is only one cover for the hard drive as well as the memory module.
    • Remove the Phillips screw on the bottom right corner of the cover.
  2. Dell Inspiron 14z Memory module Replacement: step 2, image 1 of 3 Dell Inspiron 14z Memory module Replacement: step 2, image 2 of 3 Dell Inspiron 14z Memory module Replacement: step 2, image 3 of 3
    • Use a plastic opening tool to unsnap the cover from the back case.
    • Move the tool gently along the corner of the cover.
    • The screw that holds the cover on, has a spring clip that keeps the screw attached to the cover. during removal of the screw, this clip might come of.
  3. Dell Inspiron 14z Memory module Replacement: step 3, image 1 of 3 Dell Inspiron 14z Memory module Replacement: step 3, image 2 of 3 Dell Inspiron 14z Memory module Replacement: step 3, image 3 of 3
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up
    • With the securing clips spread, the memory module will pop up.
    • Remove the memory module and replace as needed.
oldturkey03
791,361 Reputation
119 Guides authored
Global Fixers Member of Global Fixers
Community
35 Members
603 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,805
