Dell Inspiron 15 3541 Battery Replacement
Allison
Allison and 2 other contributors
Last updated on May 17, 2016
5 seconds - 5 minutes
Very easy
Introduction
Go to step 1
Before starting this guide, make sure your laptop is powered completely off and detached from the power cable. This replacement will be helpful to learn for replacing most other components of the laptop, as well as, replacing the battery itself.
  1. Dell Inspiron 15 3541 Battery Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 15 3541 Battery Replacement, Battery: step 1, image 2 of 2
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 3541 Battery Replacement: step 2, image 1 of 1
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
3 other people completed this guide.
Allison
571 Reputation
2 Guides authored
2 Comments
Can you do a guide on how to change a CPU on this computer?
F0RS3 Topaz - Reply
During this, the locks in side of this gets dispalced from there places so battery is not locking now. How to repair those locks?.
Vivek Goyenka - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 19
All Time: 1,871
