Dell Inspiron 15 3541 Keyboard Replacement
  1. Dell Inspiron 15 3541 Keyboard Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 15 3541 Keyboard Replacement, Battery: step 1, image 2 of 2
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 3541 Keyboard Replacement: step 2, image 1 of 1
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
  3. Dell Inspiron 15 3541 Keyboard Replacement, Keyboard: step 3, image 1 of 2 Dell Inspiron 15 3541 Keyboard Replacement, Keyboard: step 3, image 2 of 2
    • Open the laptop and fully extend the screen.
    • Using the nylon spudger, pry the keyboard off the laptop body.
    • Using your hands, remove the keyboard from the body and place it facedown on the track pad. There will be a cord connecting the laptop and the keyboard: keep this cord intact.
  4. Dell Inspiron 15 3541 Keyboard Replacement: step 4, image 1 of 2 Dell Inspiron 15 3541 Keyboard Replacement: step 4, image 2 of 2
    • Unhook the connector and you can now remove the keyboard from the laptop
    • If your version of this laptop has a backlit keyboard, there will be two connectors; the one highlighted orange will also have to be removed.
8 other people completed this guide.
Allison
562 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 31
All Time: 3,396
