Dell Inspiron 15 3565 Display Assembly Replacement
Terrence15
Terrence15 and one other contributor
Last updated on November 22, 2019
6 - 15 minutes
Moderate
Community-Contributed Guide
Introduction
Go to step 1
In this guide, we will be showing you how to remove and replace the Display Assembly.
Tools
  1. Dell Inspiron 15 3565 Display Assembly Replacement, Remove the Screws: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the three screws (2.5x8) that secure the display hinges to the palm-rest assembly.
  2. Dell Inspiron 15 3565 Display Assembly Replacement, Open the Display Hinges: step 2, image 1 of 1
    • Open the display hinges to an angle of 90 degrees.
  3. Dell Inspiron 15 3565 Display Assembly Replacement, Peeling the Tape: step 3, image 1 of 1
    • Peel the tape that secures the display cable to the palm-rest assembly.
  4. Dell Inspiron 15 3565 Display Assembly Replacement, Open the Latch: step 4, image 1 of 1
    • Open the latch and disconnect the display cable.
  5. Dell Inspiron 15 3565 Display Assembly Replacement, Open the Latch: step 5, image 1 of 1
  6. Dell Inspiron 15 3565 Display Assembly Replacement, Note the Routing: step 6, image 1 of 1
    • Note the display cable routing and remove the display cable from the routing guides on the palm-rest assembly.
  7. Dell Inspiron 15 3565 Display Assembly Replacement, Note the Antenna Cable: step 7, image 1 of 1
    • Note the antenna cable routing and remove the cable from its routing guides on the palm-rest assembly.
  8. Dell Inspiron 15 3565 Display Assembly Replacement, Open the Palm-Rest Assembly: step 8, image 1 of 1
    • Open the palm-rest assembly at an angle and slide it off the display assembly.
  9. Dell Inspiron 15 3565 Display Assembly Replacement, Placing the Display Assembly: step 9, image 1 of 1
    • Place the NEW display assembly on a clean, flat surface.
  10. Dell Inspiron 15 3565 Display Assembly Replacement, Placing the Palm-Rest Assembly: step 10, image 1 of 1
    • Place the palm-rest assembly on the display assembly.
  11. Dell Inspiron 15 3565 Display Assembly Replacement, Close the Hinges: step 11, image 1 of 1
    • Close the display hinges and align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
  12. Dell Inspiron 15 3565 Display Assembly Replacement, Replace the Screws: step 12, image 1 of 1
    • Replace the three screws (2.5x8) that secure the display hinges to the palm-rest assembly.
  13. Dell Inspiron 15 3565 Display Assembly Replacement, Routing the Antenna Cables: step 13, image 1 of 1
    • Route the antenna cables through the routing guides on the palm-rest assembly.
  14. Dell Inspiron 15 3565 Display Assembly Replacement, Connecting the Display Cable: step 14, image 1 of 1
    • Connect the display cable and close the latch to secure the cable.
  15. Dell Inspiron 15 3565 Display Assembly Replacement, Route the Display Cable: step 15, image 1 of 1
    • Route the display cable through the routing guides on the palm-rest assembly
  16. Dell Inspiron 15 3565 Display Assembly Replacement, Adhering the Tape: step 16, image 1 of 1
    • Adhere the tape that secures the display cable to the palm-rest assembly.
    • Close the display and turn the computer over.
Finish Line
Terrence15
79,555 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,985 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 892
