Dell Inspiron 15 3565 Memory Module Replacement
  1. Dell Inspiron 15 3565 Memory Module Replacement, Popping up the Memory Module: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
  2. Dell Inspiron 15 3565 Memory Module Replacement, Removing the Memory Module: step 2, image 1 of 1
    • Slide and remove the memory module from the memory-module slot.
  3. Dell Inspiron 15 3565 Memory Module Replacement, Align the Notch: step 3, image 1 of 1
    • Align the notch on the memory module with the tab on the memory-module slot and slide it firmly into the slot at an angle.
  4. Dell Inspiron 15 3565 Memory Module Replacement, Installing the Memory Module: step 4, image 1 of 1
    • Press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Finish Line
Terrence15
79,888 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,994 Guides authored
1 Guide Comment
What Laptop is this for? I guess the disassembly must be somewhere else.
Don Minish - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 13
All Time: 1,026
