Dell Inspiron 15 3568 Display Assembly Replacement
  1. Dell Inspiron 15 3568 Display Assembly Replacement, Open the Display: step 1, image 1 of 1
  2. Dell Inspiron 15 3568 Display Assembly Replacement, Note the Antenna Cable: step 2, image 1 of 1
    • Note the antenna cable routing and remove the antenna cables from its routing guides on the computer base.
  3. Dell Inspiron 15 3568 Display Assembly Replacement, Remove the Cable: step 3, image 1 of 1
    • Note the display cable routing and remove the cable from its routing guides on the computer base.
  4. Dell Inspiron 15 3568 Display Assembly Replacement, Remove the Screws: step 4, image 1 of 1
    • Remove the screws that secure the display hinges to the computer base.
  5. Dell Inspiron 15 3568 Display Assembly Replacement, Lifting the Display Assembly: step 5, image 1 of 1
    • Carefully lift the display assembly off the computer base.
  6. Dell Inspiron 15 3568 Display Assembly Replacement, Align the Screw Holes: step 6, image 1 of 1
    • Align the screw holes on the display hinges with the screw holes on the computer base.
  7. Dell Inspiron 15 3568 Display Assembly Replacement, Replace the Screws: step 7, image 1 of 1
    • Replace the screws that secure the display hinges to the computer base.
  8. Dell Inspiron 15 3568 Display Assembly Replacement, Route the Display Cable: step 8, image 1 of 1
    • Route the display cable through its routing guides on the computer base.
  9. Dell Inspiron 15 3568 Display Assembly Replacement, Routing the Antenna Cables: step 9, image 1 of 1
    • Route the antenna cables through its routing guides and slide the antenna cables through the slot on the computer base.
    • Close the display and turn the computer over.
Finish Line
Terrence15
79,522 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,985 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 9
All Time: 622
