Introduction
This guide will teach you to remove the back case.
This should be done before most repairs of the 5502.
Save and close all open files and exit all open applications.
Shut down your computer. Click Start > Shut down.
Disconnect your computer and all attached devices from their electrical outlets.
Disconnect all attached network devices and peripherals, such as keyboard, mouse, and monitor from your computer.
In the back there are 9 screws.
(captive) M2x7.5
M2x4
Unscrew these and store in a safe place. (eg: nescafe cup, container )
Using a plastic scribe, pry the base cover starting from the recess at the display hinge and work your way around the sides to remove the base cover.
The sticker and the cable connector(below the sticker)
Peel the tape and disconnect the battery cable from the system board.
Press and hold the power button for five seconds to ground the computer and drain the flea power.
If you were following another article and was said to follow this guide, now you can go and follow it/continue in the step you stopped!
