Dell Inspiron 15 5577 Gaming Battery Replacement
  1. Dell Inspiron 15 5577 Gaming Battery Replacement, Battery: step 1, image 1 of 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Unscrew the back cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 15 5577 Gaming Battery Replacement: step 2, image 1 of 1
    • Remove the back cover using an opening tool.
  3. Dell Inspiron 15 5577 Gaming Battery Replacement: step 3, image 1 of 2 Dell Inspiron 15 5577 Gaming Battery Replacement: step 3, image 2 of 2
    • Use a T8 Torx driver to remove the five screws around the battery.
  4. Dell Inspiron 15 5577 Gaming Battery Replacement: step 4, image 1 of 1
    • Remove the Battery Cable by gently tugging it perpendicular from the surface it is attached to.
  5. Dell Inspiron 15 5577 Gaming Battery Replacement: step 5, image 1 of 1
    • Pull the battery out of the laptop by prying it away from the laptop. If you're having difficulty removing it, you can also use a plastic opening tool.
[deleted]
346 Reputation
2 Guides authored
One Comment
Thank you, you guys rock
Random User - Reply
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 53
All Time: 5,312
