Dell Inspiron 15 5577 Gaming Hard Drive Replacement
  1. Dell Inspiron 15 5577 Gaming Hard Drive Replacement, Disconnect the Hard Drive Cable: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Using the pull-tab, disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 15 5577 Gaming Hard Drive Replacement, Remove the Screws: step 2, image 1 of 1
    • Remove the four screws (M2x5) that secure the hard-drive assembly to the computer base.
  3. Dell Inspiron 15 5577 Gaming Hard Drive Replacement, Lifting the Hard Drive Assembly: step 3, image 1 of 1
    • Lift the hard-drive assembly, along with its cable, off the computer base.
  4. Dell Inspiron 15 5577 Gaming Hard Drive Replacement, Disconnecting the Interposer: step 4, image 1 of 1
    • Disconnect the interposer from the hard-drive assembly.
  5. Dell Inspiron 15 5577 Gaming Hard Drive Replacement, Remove the Screws: step 5, image 1 of 1
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  6. Dell Inspiron 15 5577 Gaming Hard Drive Replacement, Remove the Hard-Drive Bracket: step 6, image 1 of 1
    • Remove the hard-drive bracket off the hard drive.
  7. Dell Inspiron 15 5577 Gaming Hard Drive Replacement, Align the Screw Holes: step 7, image 1 of 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  8. Dell Inspiron 15 5577 Gaming Hard Drive Replacement, Replace the Screws: step 8, image 1 of 1
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  9. Dell Inspiron 15 5577 Gaming Hard Drive Replacement, Connect the Interposer: step 9, image 1 of 1
    • Connect the interposer to the hard-drive assembly.
  10. Dell Inspiron 15 5577 Gaming Hard Drive Replacement, Align the Screw Holes: step 10, image 1 of 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  11. Dell Inspiron 15 5577 Gaming Hard Drive Replacement, Replace the Screws: step 11, image 1 of 1
    • Replace the four screws (M2x5) that secure the hard-drive assembly to the computer base.
  12. Dell Inspiron 15 5577 Gaming Hard Drive Replacement, Connect the Hard Drive Cable: step 12, image 1 of 1
    • Connect the hard-drive cable to the connector on the system board.
Finish Line
Terrence15
79,309 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,984 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 9
All Time: 2,780
