Dell Inspiron 15 5584 Display Assembly Replacement
  1. Dell Inspiron 15 5584 Display Assembly Replacement, Bottom Cover: step 1, image 1 of 1
    • Make sure to turn off and unplug your laptop before starting.
    • Turn over the laptop so that the bottom is facing upwards, and the Inspiron logo is upside-down.
  2. Dell Inspiron 15 5584 Display Assembly Replacement: step 2, image 1 of 3 Dell Inspiron 15 5584 Display Assembly Replacement: step 2, image 2 of 3 Dell Inspiron 15 5584 Display Assembly Replacement: step 2, image 3 of 3
    • Remove the seven 7 mm screws from the bottom using a Phillips #0 screwdriver.
    • Loosen the two captive back corner screws using a Phillips #0 screwdriver.
    • The two corner screws are not removable. A clicking sounds indicates that the screw is fully loosened.
  3. Dell Inspiron 15 5584 Display Assembly Replacement: step 3, image 1 of 2 Dell Inspiron 15 5584 Display Assembly Replacement: step 3, image 2 of 2
    • Slide an iFixit opening tool underneath the right side USB port and the keyboard.
    • Gently trace the iFixit opening tool along the entire outer rim of the laptop, carefully applying an upwards pressure.
    • Be careful not to force open the plate or push too much off without loosening the other sides. This can cause the bottom cover to crack.
  4. Dell Inspiron 15 5584 Display Assembly Replacement: step 4, image 1 of 2 Dell Inspiron 15 5584 Display Assembly Replacement: step 4, image 2 of 2
    • Gently pry off the bottom cover from the laptop.
    • Use the iFixit opening tool to loosen any spots you may have missed from Step 3.
  5. Dell Inspiron 15 5584 Display Assembly Replacement, Battery: step 5, image 1 of 2 Dell Inspiron 15 5584 Display Assembly Replacement, Battery: step 5, image 2 of 2
    • Remove the four 3.5 mm screws holding the battery down with a JIS #0 screwdriver.
  6. Dell Inspiron 15 5584 Display Assembly Replacement: step 6, image 1 of 3 Dell Inspiron 15 5584 Display Assembly Replacement: step 6, image 2 of 3 Dell Inspiron 15 5584 Display Assembly Replacement: step 6, image 3 of 3
    • Detach the motherboard connector tab from the top left of the battery.
    • Remove the battery from the device.
    • Be sure to carefully wiggle the connector out from the battery socket. Ripping it out too forcefully could damage the socket.
  7. Dell Inspiron 15 5584 Display Assembly Replacement, Fan: step 7, image 1 of 3 Dell Inspiron 15 5584 Display Assembly Replacement, Fan: step 7, image 2 of 3 Dell Inspiron 15 5584 Display Assembly Replacement, Fan: step 7, image 3 of 3
    • Loosen the four captive 3.5 mm screws securing the heat sink to the motherboard using a Phillips #0 screwdriver.
    • Remove the CPU plate cover from the motherboard and safely place it off to the side.
  8. Dell Inspiron 15 5584 Display Assembly Replacement: step 8, image 1 of 3 Dell Inspiron 15 5584 Display Assembly Replacement: step 8, image 2 of 3 Dell Inspiron 15 5584 Display Assembly Replacement: step 8, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the two 3.5 mm screws from the fan with a JIS #0 screwdriver.
    • Detach the fan connector from the motherboard using a pair of tweezers.
  9. Dell Inspiron 15 5584 Display Assembly Replacement: step 9, image 1 of 2 Dell Inspiron 15 5584 Display Assembly Replacement: step 9, image 2 of 2
    • Gently lift the fan from the device and de-thread the LCD display cable.
    • Remove the fan from the device.
  10. Dell Inspiron 15 5584 Display Assembly Replacement, DC Jack: step 10, image 1 of 2 Dell Inspiron 15 5584 Display Assembly Replacement, DC Jack: step 10, image 2 of 2
    • Remove the three 6 mm screws holding down the screen hinge in the upper right corner using a JIS #0 screwdriver.
  11. Dell Inspiron 15 5584 Display Assembly Replacement: step 11, image 1 of 2 Dell Inspiron 15 5584 Display Assembly Replacement: step 11, image 2 of 2
    • Grasp the screen hinge and lift it up.
  12. Dell Inspiron 15 5584 Display Assembly Replacement: step 12, image 1 of 3 Dell Inspiron 15 5584 Display Assembly Replacement: step 12, image 2 of 3 Dell Inspiron 15 5584 Display Assembly Replacement: step 12, image 3 of 3
    Buy
    • Lift up the sticker covering the DC jack connector using tweezers.
    • Using tweezers, detach the motherboard connector and lift the jack out of place.
    • Remove the DC jack from the laptop.
  13. Dell Inspiron 15 5584 Display Assembly Replacement, Wi-Fi Card: step 13, image 1 of 3 Dell Inspiron 15 5584 Display Assembly Replacement, Wi-Fi Card: step 13, image 2 of 3 Dell Inspiron 15 5584 Display Assembly Replacement, Wi-Fi Card: step 13, image 3 of 3
    • Remove the single 3 mm screw that holds down the Wi-Fi card using a Phillips #0 screwdriver.
    • Remove the Wi-Fi card from the motherboard.
  14. Dell Inspiron 15 5584 Display Assembly Replacement, Display Assembly: step 14, image 1 of 2 Dell Inspiron 15 5584 Display Assembly Replacement, Display Assembly: step 14, image 2 of 2
    • Remove the four 6 mm screws from the hinge in the upper left corner with a JIS #0 screwdriver.
  15. Dell Inspiron 15 5584 Display Assembly Replacement: step 15, image 1 of 2 Dell Inspiron 15 5584 Display Assembly Replacement: step 15, image 2 of 2
    • Grab the hinge and push upwards.
  16. Dell Inspiron 15 5584 Display Assembly Replacement: step 16, image 1 of 3 Dell Inspiron 15 5584 Display Assembly Replacement: step 16, image 2 of 3 Dell Inspiron 15 5584 Display Assembly Replacement: step 16, image 3 of 3
    Buy
    • Use tweezers to peel off the sticky label covering the display cable port.
    • Use tweezers to unlatch the cable.
    • Grasp the display cable firmly and remove it.
  17. Dell Inspiron 15 5584 Display Assembly Replacement: step 17, image 1 of 2 Dell Inspiron 15 5584 Display Assembly Replacement: step 17, image 2 of 2
    • Lift the underside of the device and slightly open the laptop.
    • Pull the bottom half of the device off of the hinges.
Kristen Gismondi
91,898 Reputation
241 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,425 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 199
