Dell Inspiron 15 5584 Fan Replacement
  1. Dell Inspiron 15 5584 Fan Replacement, Bottom Cover: step 1, image 1 of 1
    • Make sure to turn off and unplug your laptop before starting.
    • Turn over the laptop so that the bottom is facing upwards, and the Inspiron logo is upside-down.
  2. Dell Inspiron 15 5584 Fan Replacement: step 2, image 1 of 3 Dell Inspiron 15 5584 Fan Replacement: step 2, image 2 of 3 Dell Inspiron 15 5584 Fan Replacement: step 2, image 3 of 3
    • Remove the seven 7 mm screws from the bottom using a Phillips #0 screwdriver.
    • Loosen the two captive back corner screws using a Phillips #0 screwdriver.
    • The two corner screws are not removable. A clicking sounds indicates that the screw is fully loosened.
  3. Dell Inspiron 15 5584 Fan Replacement: step 3, image 1 of 2 Dell Inspiron 15 5584 Fan Replacement: step 3, image 2 of 2
    • Slide an iFixit opening tool underneath the right side USB port and the keyboard.
    • Gently trace the iFixit opening tool along the entire outer rim of the laptop, carefully applying an upwards pressure.
    • Be careful not to force open the plate or push too much off without loosening the other sides. This can cause the bottom cover to crack.
  4. Dell Inspiron 15 5584 Fan Replacement: step 4, image 1 of 2 Dell Inspiron 15 5584 Fan Replacement: step 4, image 2 of 2
    • Gently pry off the bottom cover from the laptop.
    • Use the iFixit opening tool to loosen any spots you may have missed from Step 3.
  5. Dell Inspiron 15 5584 Fan Replacement, Battery: step 5, image 1 of 2 Dell Inspiron 15 5584 Fan Replacement, Battery: step 5, image 2 of 2
    • Remove the four 3.5 mm screws holding the battery down with a JIS #0 screwdriver.
  6. Dell Inspiron 15 5584 Fan Replacement: step 6, image 1 of 3 Dell Inspiron 15 5584 Fan Replacement: step 6, image 2 of 3 Dell Inspiron 15 5584 Fan Replacement: step 6, image 3 of 3
    • Detach the motherboard connector tab from the top left of the battery.
    • Remove the battery from the device.
    • Be sure to carefully wiggle the connector out from the battery socket. Ripping it out too forcefully could damage the socket.
  7. Dell Inspiron 15 5584 Fan Replacement, Fan: step 7, image 1 of 3 Dell Inspiron 15 5584 Fan Replacement, Fan: step 7, image 2 of 3 Dell Inspiron 15 5584 Fan Replacement, Fan: step 7, image 3 of 3
    • Loosen the four captive 3.5 mm screws securing the heat sink to the motherboard using a Phillips #0 screwdriver.
    • Remove the CPU plate cover from the motherboard and safely place it off to the side.
  8. Dell Inspiron 15 5584 Fan Replacement: step 8, image 1 of 3 Dell Inspiron 15 5584 Fan Replacement: step 8, image 2 of 3 Dell Inspiron 15 5584 Fan Replacement: step 8, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the two 3.5 mm screws from the fan with a JIS #0 screwdriver.
    • Detach the fan connector from the motherboard using a pair of tweezers.
  9. Dell Inspiron 15 5584 Fan Replacement: step 9, image 1 of 2 Dell Inspiron 15 5584 Fan Replacement: step 9, image 2 of 2
    • Gently lift the fan from the device and de-thread the LCD display cable.
    • Remove the fan from the device.
Sam Vorn
977 Reputation
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 24
All Time: 435
