Dell Inspiron 15 7560 Display Assembly Replacement
  1. Dell Inspiron 15 7560 Display Assembly Replacement, Note the Routing: step 1, image 1 of 1
  2. Dell Inspiron 15 7560 Display Assembly Replacement, Open the Latch: step 2, image 1 of 1
    • Open the latch and disconnect the display cable from the system board.
  3. Dell Inspiron 15 7560 Display Assembly Replacement, Open the Display: step 3, image 1 of 1
    • Open the display at an angle of 90 degrees.
  4. Dell Inspiron 15 7560 Display Assembly Replacement, Placing the Computer: step 4, image 1 of 1
    • Place the computer on the edge of a table so that the palm rest and keyboard assembly is on the table and the display assembly extends past the table edge with the display hinges facing up.
  5. Dell Inspiron 15 7560 Display Assembly Replacement, Remove the Screws: step 5, image 1 of 1
    • Remove the four screws (M2.5x5) that secure the display hinges to the palm rest and keyboard assembly.
  6. Dell Inspiron 15 7560 Display Assembly Replacement, Lifting the Display Assembly: step 6, image 1 of 1
    • Lift the display assembly off the palm rest and keyboard assembly.
  7. Dell Inspiron 15 7560 Display Assembly Replacement, Placing the Assembly: step 7, image 1 of 1
    • Place the palm rest and keyboard assembly on the edge of a table with the keyboard facing down.
  8. Dell Inspiron 15 7560 Display Assembly Replacement, Align the Screw Holes: step 8, image 1 of 1
    • Align the screw holes on the display hinges with the screw holes on the palm rest and keyboard assembly.
  9. Dell Inspiron 15 7560 Display Assembly Replacement, Replace the Screws: step 9, image 1 of 1
    • Replace the four screws (M2.5x5) that secure the display assembly to the palm rest and keyboard assembly.
  10. Dell Inspiron 15 7560 Display Assembly Replacement, Close the Display: step 10, image 1 of 1
    • Close the display and turn the computer over.
  11. Dell Inspiron 15 7560 Display Assembly Replacement, Sliding the Display Cable: step 11, image 1 of 1
    • Slide the display cable into the connector on the system board and close the latch to secure the cable.
  12. Dell Inspiron 15 7560 Display Assembly Replacement, Routing the Antenna Cables: step 12, image 1 of 1
    • Route the antenna cables through the routing guides on the fan.
Finish Line
2 other people completed this guide.
Terrence15
79,309 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,984 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 975
